Well, if it were experimental, it would probably be a noisy, sparse data set, interpolated with a curve. Instead, they present a PWL graph. It's a Bode plot derived from the relevant limits (V and P).
Easy enough to see. Take this one for example,
The RC circuits are simply crossovers, where the high value resistors matter at low frequency, and the low value resistors matter at high frequency.
