I did a teardown of this HP model R/T3000I transformerless 3000VA UPS, which seems to be a re-branded unit made by Eaton. The input and output voltages are from 200 to 240V, and it uses a 120V battery.
Of course, there are no schematics for it. The only documentation I've found are user manuals that only discuss the user interfaces, and electrician-oriented installation details. It also seems that the same model number, but of different vintages, may have completely different internals - some seem to be not transformerless.
Here's the main power board:-
And the In/Out board that connects to the input and output AC sockets, and to the power board via 3 main conductors (labelled line,neutral and load)
Being completely unfamiliar with these devices, I was simply guessing how it works as I went. My understanding is that the output of the UPS always comes from the converter, thus providing a clean conditioned output (online mode). But when a fault is detected in the converter, bypass mode is entered whereby the output power comes directly from the incoming mains. And of course, when the mains input fails, the converter is powered by the battery.
I want to do a follow-up based on a proper understanding of the unit, so I reverse-engineered the power circuitry of the main power board. But it's not quite what I was expecting, and I'm struggling to see how it works. I'm hoping someone can explain it to me. Here's my schematic:-
It looks like Q5, Q6, Q9, and Q10 form the main H-bridge that is driven by sinusoidal PWM signals, and the high frequency PWM filtered out by L1, L3 and C5, leaving pure sinewave power going to the load. Beyond that, I'm stuck:-
BUS+ looks to be powered during normal operation from LINE via K6, F2A, K5, CS2 and rectified by D22, and during power loss, from the battery via K3.
But I can't see how the negative DC bus (BUS-) gets powered.
In battery mode, maybe via K4, K5, CS2 and D23?
And in normal online mode, ??!!
Do D22, D23 and Q7, Q8 form some sort of synchronous rectifier to power the DC BUS?
Or are Q7 and Q8 part of the output inverter in some sort of H5 topology?
I keep looking for (and not finding) a more "solid" connection from BAT- and/or Neutral (via D23?) to BUS-. I've triple checked all this on the PCB, and I'm pretty sure my schematic is correct.
More questions:-
Q4 is on the large heatsink with the others, what does it do?
My guess is that Q20 is involved with charging the battery, but can't see how.
What is the function of the huge inductor L2?
How can this produce 240V output from a 120V battery?
Any insights or clues as to how this thing operates would be most appreciated. Thanks...
