Author Topic: Estimate power consumption  (Read 947 times)
Offline the_eagleTopic starter
« on: December 01, 2018, 02:58:01 pm »
I have a symmetrical OTA as shown in the image attached. At a high level we can consider it similar to an op-amp so golden rules apply.
The current source (I_ref) generates a supply of 100uA from 5V and V_b is 1.55V. If the output is 2.5V (the midrail voltage) in open loop configuration with input 2.5V and 2.497V for V+ and V- respectively. How can I estimate the power consumption of the device?
Using the golden rules, we know that there is no input current in the op-amp input terminals; but then I get stuck on how to combine power dissipated by the current source and V_b.
« Last Edit: December 01, 2018, 03:00:07 pm by the_eagle »
Offline Wimberleytech
Re: Estimate power consumption
« Reply #1 on: December 01, 2018, 06:44:46 pm »
Here you go.  Vb does not cost anything if you design it as I have shown.
The following users thanked this post: the_eagle
« Reply #2 on: December 02, 2018, 11:34:18 am »
So those extra 550uA (650uA - Iref) are taken from the power supply of Iref, is it correct?
« Reply #3 on: December 02, 2018, 12:22:09 pm »
If Iref is not sourced from Vdd, then the total Vdd current is 550 ua
« Reply #4 on: December 03, 2018, 01:54:42 am »
I understood the reasoning process! Thank you very much!
