Hi all,
Once again I need the advice of you guys
. I am working on a project that I need to fix a small piece of flex PCB on a curved surface (wrap half way around a cylinder of approx 20mm Diameter) I can used any double sided tape which is thicker than 0.1mm as the diameter of the cylinder and the flex PCB should not exceed 20mm+Flex+0.1 I was thinking of using a form of adhesive (i.e. spray adhesive) to permanently glue it to the surface but I am not sure which type of adhesive will work best on flex PCBs
. Does anyone here have an experience with a glue that they used for a similar application?
