Author Topic: high voltage e-load  (Read 12646 times)
Re: high voltage e-load
« Reply #25 on: May 13, 2014, 04:08:38 pm »
It will destroy it long term, but spare magnetrons are just a run to the nearest scrap yard away and pay $1 for them or even free if you look around on trash day.
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #26 on: May 14, 2014, 06:30:10 am »
AFAIK, oven type magnetrons use thoriated tungstent filaments.
In that case they should work indefinately* :) That's the method normally used to control beam current in x-ray tubes and depending on how constant a current is needed may actually be suitable for the OP's requirements.
Still I get the impression his boss may not like it.
*well, for their normal service life.
