I build and sell to the amateur radio and shortwave listener market a voltage probe active antenna. It's basically a high input impedance source follower, with careful attention to maximizing dynamic range and minimizing noise figure. The input stage is a BF996 dual gate FET, which drives a BFQ19 follower, and the output is a BFQ19/BFQ149 CS follower. Frequency coverage is 10 KHz - 30 MHz where an input filter starts rolling off the coverage to avoid FM broadcast band overload. Without the input filter, it's usable well above 100 MHz. This is, excepting that low frequency response does not extend to 0, an FET scope probe. (It's also a bit physically large to use as a probe.)
In developing the antenna, some early experiments involved driving a 50 ohm load directly with the BF996 and I found it does a credible job, based purely on amplitude. It does not provide the best intermodulation performance, so a more complex circuit is required, but you should not see more than 6 dB loss into 50 ohm load.
The input capacitance of a BF996, plus stray trace capacitance and, in the case of my active antenna, a disconnect relay, is on the order of 8-10 pF. To prevent the input blocking capacitor from being a limiting factor (voltage divider effect) it's necessary to make it considerably larger - I use a high voltage (630V) 1000 pF C0G capacitor.
If you don't want to fiddle with a physically small SMD part like the BF996, a TO-92 style J310 is nearly as good and much easier to throw together in a one-off arrangement. For minimum distortion, set the gate bias to provide about 20 mA idle current through the J310. That's a lot more than most people think of when an FET is used, but the "sweet spot" for the J310's intermodulation distortion is in that range.
