Thanks sprocket. I was asked about the possibility to design an inertial tracking system for penguins, i.e. accelerometer + gyro + memory + micro + battery. And (if possible) pressure & temp sensor (meas spec have the MS5803-30BA, but this is not a priority right now). Without the pressure sensor there is no need of any contact with the external environment, so it should make the design easier.
But on the other hand, the accelerometer and gyro packages are affected by stress, they should be isolated of the external pressure (shield of some kind if potting is used, not for RF but for pressure).
And yes, it will be not cheap, but the cost is directly linked to solve the potting issue (not case anymore), and I'm trying to have an idea of the effort involved.
