Hello
Some op amplifier provide very low noise but when a low pass filter is added that generate noise ( after amplification OK ) SO :
Does there is designs requirements to built a low noise filter as a low pass 150 Hz filter ?
A common way is to fit a passive resistor + cap at the op amp output as described in Analog / TI docs
Regards
OS
