Hi all,
I know, uCurrent rules, but for those that use bipolar power supplies and bridge driver (half or full), highside current measurements are required.
This is what I came up with for each PS output:
I made a pcb through hole version using 1k ohm precision temperature stablized metal film resistors (measured to < 0.01%) that I had on stock.
There are 1k 0.01% digikey surface mountable resistors for about 2 bucks a piece. (notice the extra 10x precision compared to the uC)
The total number of 1k 0.01% resistors need to make 2 Highside MilliCurrents would be 22.
https://www.digikey.com/en/products/detail/stackpole-electronics-inc/RNCF0805TKY1K00/2269700Even if you get those, you still need extra non precision, but temperature stablized resistors and a couple of 18 turn through hole pots for the output stage. (my design)
The common mode voltage seems to be the catch for highside measurements.
Postive non inverting bias current can be zeroed out by using the relative function, but a Negative non inverting bias current is opposite.
The negative non inverting bias current offset voltage can be relatived out if you turn on the oscilations without the power to the input lead follower transistor connected to the highside mC while the PS still connected to the mC.
(The 11 ohms on the input is from the shunt resistance from the current measurement from the mastech multimeters I have. Also the PS on the output voltage meter is the relative function of the multimeter set at 8.8uV)
This gain mulitplication per stage variation is the lowest in offset voltage in B2spice in order to maximize the bandwidth.
