Hello everyone,
need some help advice on:
LTC2400 connected directly by SPI to arduino board , everything fine , and there is below SPI protocol:
( as you can see all, perfect, top channel enable chip, 2-nd spi data, 3-rd clock; I'm able to decode it )
Then I added ADUM1412A directly between LTC and arduino ....
ADUM on ADC, LTC side:
ADUM on arduino side:
( sorry images not in scale, but channel sequence the same , despite color )
I don't quite understanding what happens with LTC output when the arduino was replaced by ADUM ....
it a direct connection; +5V feed on both ends
I also may assume, ADUM malfunction ..... I have no clue, it my first attempt to use isolator ...
