I keep coming back to this project over the last few years whenever I have some time. It's a joystick controller for telescope mounts (with libraries of sky objects, GPS, bluetooth, built in joystick and an external joystick connection.)
The case is 3D printed (optically, laser sintered nylon) in two materials. I've been using threaded inserts in the plastic which seem to work very well.
Mike in Alaska
