Ok, so here is my problem
I have a buck-boost circuit and i'm having trouble driving the high-side mosfet. Problem is, my input range is 6V-35V. Initially we wanted to use a voltage doubler, but unfortunately at 6V input voltage would result in 12v (theoretical), and this 12V would not be enough to drive the mosfet we have picked as we want at least 10V VGS, hence 6V in, 16V - > vgs.
Does anyone have any ideas how I can get around this problem? A nice chip that has an output function such as
X volts in,
X+10 Volts out over a large voltage range?
