Bonjour à tous !
juste found this interesting old thread now.
Seems like killing flies with an A bomb.
In my over half century of analog, RF, power design, we used prototype with perf ( Vero) board, pad per hole, and the pictured 0.1" socket type bread boards.
I used pin headers, or bare solid bus wire in the breadboard. Wire lead, Pomona EZ hook, or soldered to pin or bus.
Alternative use stranded #24..28, wire or ribbon cable, separate, strip, tin ends. Insert direct into board.
The cleverest solution is the simplist.
Bon Soirée
Jon
