Author Topic: How do you imitate ground?  (Read 3843 times)
Offline jmctechTopic starter
« on: October 07, 2016, 01:48:36 am »
I am working on a project that will basically imitate faults on low volt electrical lines. We use testers made by JDSU and Fluke that need a ground reference to fully test a cable pair for things like opens, shorts, capacitive balance across a pair and also to ground. My question is how would I imitate ground reference?
Thanks for looking and any help you could provide.
Jason
Offline singapol
  • Country: sg
Re: How do you imitate ground?
« Reply #1 on: October 07, 2016, 05:47:46 am »
Offline jitter
« Reply #2 on: October 07, 2016, 06:13:45 am »
Jason
I think the first question you must try to find the answer to is "what does 'referenced to' mean?".
Once you understand that, your question above will be answered automatically.
Singapol's links should get you on your way.
Offline daqq
  • Country: sk
    • My site
« Reply #3 on: October 07, 2016, 06:23:14 am »
Sorry, couldn't resist.
The following users thanked this post: BobsURuncle
Offline jitter
« Reply #4 on: October 07, 2016, 10:54:14 am »
On a more serious note, a former colleauge used to live in Peru and earting was often done by running a wire to a wall of a building...  :palm:
« Last Edit: October 07, 2016, 04:20:27 pm by jitter »
Offline Back2Volts
« Reply #5 on: October 07, 2016, 02:16:51 pm »
I almost posted a flower pot.   You beat me to it!
Offline Marco
« Reply #6 on: October 07, 2016, 02:54:22 pm »
I prefer to use ground as a synonym for circuit virtual ground, because that's how it's almost always used anyway. For actual ground I'll use the tautology earth ground.
Why would you want to imitate ground reference? What's wrong with simply using earth ground? In theory you could dig a huge pit, put an electrically insulating liner in it, fill it with dirt and some water, put some grounding rods in it and have an imitated electrically floating earth environment ... but for what purpose?
« Reply #7 on: October 07, 2016, 11:12:58 pm »
It is gonna be a portable device that will be used in different training areas. A reliable ground will not always be available. The other issue is these tester send some type of impulse down the ground connection. With a single person testing it isn't an issue, but when we have 8 or 10 of these testers connected to a common ground source they interfere with each other.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Offline retrolefty
« Reply #8 on: October 07, 2016, 11:51:57 pm »
Jason
 I too think you are reading more into the 'requirement' then needed. Does the Fluke have an operations manual showing proper hook-up for DUT cable? I bet they just require that the ground lead be attached to any shielding lead(s) in the cable to perform all the measurements you stated.
Offline jitter
« Reply #9 on: October 08, 2016, 06:07:33 am »
Jason
Agreed.
That was the reason for my first reply in this thread.
What testers are they exactly? I'd like to look up a manual.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #10 on: October 08, 2016, 07:26:46 am »
another solution...
