I wouldn't recommend using 872As nowadays. They were phased out in broadcast transmitters as soon as it became possible to do so, at first using long strings of silicon diodes with equalizing resistors and capacitors across each one, then , as silicon diodes improved, direct plug-in solid state replacements for mercury rectifier tubes were developed, and almost universally adopted nearly overnight.
Mercury vapor rectifier tubes were always problematic devices, requiring careful handling and upright operation to prevent splashing mercury onto the anode or other internal parts, a perhaps hour-long "conditioning" period prior to initial operation to condense all the liquid mercury into the bottom portion of the tube, a several minute warmup period before application of plate voltage to prevent internal arcback, a limited range of ambient temperature to assure proper mercury vapor pressure, and careful shielding and filtering to remove the RF hash that they generated.
Then there is the whole hazmat disposal issue at end of life.
High voltage rectifier diodes are widely available, including from the microwave ovens you plan to scavenge the transformers from. Much more reasonable design choice than using an 872A nowadays...
