Hello
I want to find a pin compatible alternative for this device.
K9F5608U0D-PCB
https://www.datasheets360.com/search/results?query=K9F5608U0D-PCBDatasheet360 do give you alternative parts for some components. See an example for IS61WV5128EDBLL
https://www.datasheets360.com/search/results?query=IS61WV5128EDBLLSearch for the link "Cross Reference Search" on the page above.
I know these are references to obsolete parts but I have seen some usable results from Datasheet360 in the past.
Now my problem is that Datasheet360 do not provide alternatives for the K9F5608U0D-PCB.
Are any of you aware of some website or piece of software that can suggest an alternative.
Thanks
