Author Topic: Using 2.4GHz duck antennas with subghz radio?  (Read 1493 times)
Offline abhishekkumar1902Topic starter
  • Country: in
« on: December 14, 2017, 12:05:32 pm »
Since I am not from RF field, had this questions where I am using CC1350 subghz radio in one of my project and I have some of these 2.4GHz wifi duck antennas lying around, where I wanted to ask if I can use them with the CC1350 subghz radio operating at around 915 MHZ. If not, why?
« Last Edit: December 14, 2017, 12:33:59 pm by abhishekkumar1902 »
Offline hagster
Re: Using 2.4GHz duck antennas with subghz radio?
« Reply #1 on: December 14, 2017, 02:06:57 pm »
Its very hard to tell how well it will work at 915MHz since they do not publish and specs at this frequency. I doubt it will work well, because the antenna element will be too short at this frequency and the impedence match will likely be very poor also.
For a very short range link(say across a room) it may work a bit, but then I bet an 8cm bit of random wire would work better.
