Anyone try out one of these yet? It is offered by ADI, contains the following including an 18bit, 2msps ADC and an intel FPGA. Price is around $170usd. There is example software for data acquisition written in python and I think there is a data analysis package. Looks pretty cool for the hobbyist.
https://www.arrow.com/en/products/analogmax-daq1/trenz-electronic-gmbhFeatures:
- Intel® MAX 10 Commercial [10M08SAU169C8G]
- Package: UBGA-169
- Speed Grade: C8 (Slowest)
- Temperature: 0°C to 85°C
- Package compatible device 10M02...10M16 as assembly variant on request possible
- SDRAM Memory up to 64Mb, 166MHz
- Dual High-Speed USB to Multipurpose UART/FIFO IC
- 64 Mb Quad SPI Flash
- 4Kb EEPROM Memory
- 8x User LED
- Micro USB2 Receptacle 90
- 18 Bit 2MSPS Analog to Digital Converter
- 2x SMA Female Connector
- I/O interface: 23x GPIO
- Power Supply:
- 5V
- Dimension: 86.5mm x 25mm
- Others:
- Instrumentation Amplifier
- Differential Amplifier
- Operational Amplifier
I'm probably going to grab one and see if I can use it for time-nut stuff. Having those 2 sma connectors, though I think they are differentially, implemented looks interesting. Maybe I can use it as a TIC.
Jerry
