They are rated for some hundred milliamps to 1-2 Amps. Just take a smaller one, put more in parallel, leave some space on the PCB for it. Space is usually free, the pins, you only need to buy once.
The only thing you need to be aware is the increased force it requires to push down the PCB, sometimes only on one side.
