I have made a small modification so that the circuit no longer needs a 5 Meg Ohm Pot.
Here is the revised schematic:
The circuit also shows two loads resistors R5 and R6. R6 is in series with a switch. The load is stepped from 2.5mA to 5mA by the switch.
By using the stepped load like that we can observe the control loop stability.
All regulated power supplies are servo systems there is a reference that drives the demand, error amplifier and a feedback circuit.
Here is the results showing load current steps and the output voltage. You can see that the system is stable.
Opto-couplers present challenges in designing the control loop. The gain of the opto coupler, for a given part number, can vary from 50% to 200% of the nominal value. In addition the gain changes as the opto coupler ages. These may not be a concern if you are building one power supply for yourself, but if you are are planning on building several it is better to avoid opto-couplers.
Yes, the circuit is floating at the output voltage. I would strongly recommend finding a potentiometer with a plastic shaft and mounting all the control circuitry, including the body of the potiometer, inside the enclosure with only the plastic shaft sticking out.
There are many ways to do anything in electronics. I just wanted to show the forum members the traditional approach to high voltage power supplies. This idea of the floating bias supplies can be found in most power supplies greater than 20V. Below 20V emitter or source followers can be used to boost the output of an op-amp.
Regards,
Jay_Diddy_B (Not my real name, I am in disguise
