Author Topic: Help Simulating Application Circuit #5 of LTC3350 Datasheet using LTspice  (Read 1015 times)
Offline joe306Topic starter
Hello, I am trying to simulate a circuit found on page 41 of the datasheet for the LTC3350. I am using LTSpice and when I run the Simulation get the message "Pseudo-Transcient Analysis that runs forever until I hit the ESC button. That's my first problem the second is that I'm not getting the correct Vout voltage. I have all my parameters set like the datasheet.
I'll upload the datasheet and LTSpice design.
Thank you,
Joe
Offline Jay_Diddy_B
Hi.
Check these two boxes:
And it will add startup and uic to the simulation command.
Everything will work nicely.
Also:
Regards,
Jay_Diddy_B
« Last Edit: April 05, 2019, 11:04:36 pm by Jay_Diddy_B »
