Hi All,
I need advice on the power filter inductors. I am planning to build a three-phase PCB inverter board for 5 kW. At 400 V output, that is approx. 7.2 A rms output line current. The switching frequency is 30 kHz and the LC power filter LC values are calculated as 3 mH and 6 uF.
In the past, I built a 5 kHz inverter, so the L was much higher (8 mH), and I ordered it as a stand-alone pot core type from
HKR where I filled their
form with data: switching frequency, dv/dt, current, etc.
Now, since I increased the switching frequency, apart from a lower value, a lower number of turns will also be needed, so I was thinking of
putting the LC power filter inductors on the PCB board, since capactors are already there. Something similar like this:
(a),
(b),
(c),
(d), or
(e)Are there any inductor manufacturers that do Pot Core inductors for PCB mounting, where I would send waveforms and other data and they would design affordable bespoke inductors?
From the off-the-shelf product, I was able to find only
this for 3 mH and 7 Arms.
Thanks, MB
