Looks like a fairly mundane thin metal core / metal substrate PCB of the sort routinely used for LED lighting applications.
Doing the design to have a basically flat PCB bend like that and have the holes line up must have been 'Fun'.
Not cheap at that size, but quite doable for medical stuff, I dont think there is anything designed as a flex PCB here.
Regards, Dan.
