Author Topic: Help finding documentation for OCXO  (Read 3218 times)
Offline ZBIQTopic starter
« on: December 17, 2014, 07:29:16 pm »
Hi!
It is my first topic at EEEVblog. So Hello :) !
I have recently bought ocxo stable oscillator (for about 9$ - so worth it :)). It works fine, but there is no data sheet for this device.
Here is the ocxo photo:
http://img03.allegroimg.pl/photos/oryginal/48/76/94/72/4876947200
The whole pcb is disassembled from GSM transmitter. Marking on it says:
PC9203 V255
RADIOSYSTEM
SWEDEN AB
TVM 351 131 R2
It has FPGA, uC and few memories. There are also connectors: BNC and SMB. So, I think the whole PCB is GPS disciplined oscillator.
I think circuit works (after suppling voltages leds are blinking). But without documentation this board is useless...
Can you help me finding DS for OCXO?
Mateusz
Offline fcb
    • Electron Plus
Re: Help finding documentation for OCXO
« Reply #1 on: December 17, 2014, 07:41:29 pm »
Vectron maybe able to help.
Else, you can probably reverse engineer the board to work out the connections (which maybe enough for your needs).
« Reply #2 on: December 17, 2014, 08:04:27 pm »
Ive done some research on OCXO. I know where goes power supply and where comes out frequency. But there are two more pins. One is connected to DAC (by chip '224 91G722' - opamp??). Another one is unknown (maybe some Vref out?)...
This board has 6 layers (!) - reverse engineering is very hard.
Offline dannyf
« Reply #3 on: December 17, 2014, 10:09:22 pm »
The dac pin is likely the control / tunning pin: apply a voltage to it to fine-tune the output frequency.
The other is the ground pin, likely.
Offline TSL
« Reply #4 on: December 18, 2014, 02:25:30 am »
A better picture of the entire board would help, once we can see the part #'s on all the chips we might get some idea
TT
VK2XAX :: QF56if :: BMARC :: WIA :: AMSATVK
Offline babysitter
  • pushing silicon at work
« Reply #5 on: December 18, 2014, 07:02:08 am »
A DAC would only make sense on tuning voltage as dannyf pointed out. If it tunes - just load it with a resistor. Frequency shall jump between loaded and unloaded. The change might be too small to see on a scope, use a frequency counter or listen to it on a shortwave radio, best would be if you would hear a beat note. Tuned to a harmonic the jump would be more distinct.
The additional pin might be reference or for mechanical purposes (stability). If its a reference output you could see if its actually used when you load it with a resistor to ground to reduce it a few mV and check if the DAC output voltage sags accordingly.
I'm not a feature, I'm a bug! ARC DG3HDA
Offline khach
« Reply #6 on: December 18, 2014, 09:54:23 pm »
Piezo 10MHz OCXO and QK Quarzkeramik GmbH 10MHz OCXO from similar board
https://sites.google.com/site/sp7roh/
« Reply #7 on: December 19, 2014, 05:02:20 pm »
Thats fantastic ! So, from now I know pinout. Its time to check performance of the OCXO.
Tank you very much !
