I'm building a circuit that requires quad well-matched capacitors, NP0, in the 50-500pF range. "Well-matched" means ideally within 2%. Each cap will be from a signal line to GND, so bussed caps are OK.
I've looked at X2Y caps but they only provide 2 matched capacitors.
I also looked at standard array capacitors, which do have 4-cap arrays. But, the datasheets don't say anything about the matching.
Example digikey page:
https://www.digikey.com/short/92m3q85qI will be using several thousand quad caps, so manual measuring and matching is not a viable option here...
Does anyone have wisdom to share about this?
