I have that silver finish on 4 WD green hard drives, after one completely died, I had to clean all the other drives PCBs.
Failure mode is this:
1. Controller gets bad/weak signals from the heads, assumes it's just a bad sector.
2. Controller moves the data to another part of the drive, and marks the original sector as bad.
3. Error rates get worse, controller moves more files, marks more sectors as bad.
4. After days/weeks of this, whenever the computer is on the drive has activity.
5. Actual disk surface has damage from constant moving of files.
6. Drive has more bad sector than it can mark.
7. Attempt to reformat drive as last resort after saving data.
8. Reports over 10,000 unrecoverable bad sectors, marks them as bad then crashes.
9. Reboot shows drive as totally unavailable, to the BIOS!
10. Totally bricked.
