I came across this circuit in a device.The circuit applies mains AC to an IR LED, but only the hot line. What I don't understand is how the LED is driven when only the AC hot line is connected to both sides. I was thinking that maybe there is enough phase lag caused by the resistors to put adequate current into the IR LED, but it still seems suspect to me.
Edit: New info, the LED is actually two IR LEDs in reverse parallel. So that takes care of one concern. However, I still don't see how this circuit can work.
