Author Topic: TID122 any known substitutions?  (Read 450 times)
Offline CramboneTopic starter
« on: September 14, 2023, 07:56:38 pm »
I’m looking for a substitution for a TID122 any help would be appreciated!
Drew
Offline PCB.Wiz
Re: TID122 any known substitutions?
« Reply #1 on: September 14, 2023, 11:02:21 pm »
It would help to explain what that is ?
Google suggests it is a DIP14 8 rectifier diode array with common pin. Strange part.
No one is going to make that in 2023, but you could build one using a DIP14 former, if you need to service something.
For new designs, you might select something made in large enough volumes, eg parts like 2 x 1SS309
Offline coromonadalix
« Reply #2 on: September 14, 2023, 11:48:46 pm »
same here,  some details would help, and help you get some return
