Author Topic: Hand soldering of BGA chips  (Read 7789 times)
Offline djsbTopic starter
« on: August 12, 2010, 12:44:00 pm »
Has anyone had any experience of hand soldering BGA chips using hot air? There are a few video's on the sparkfun website just wondering if anyone has tried this for themselves. Thanks.
David.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
Offline slburris
Re: Hand soldering of BGA chips
« Reply #1 on: August 12, 2010, 03:08:44 pm »
I have not, but SchmartBoard has an adapter that's intriguing:
https://www.youtube.com/nealgb#p/u/6/D3PTpaB4kro
Scott
Offline NiHaoMike
    • Facebook Page
« Reply #2 on: August 12, 2010, 11:22:13 pm »
There's a way to do it with a hot plate and heat gun. Apply a special flux to the board, put the BGAs on, use the hot plate to get the board up to a preheat temperature, and the heat gun does the actual soldering. I have not actually done that with BGA, but I have done that with TSOP. BGA is definitely harder to get right and very difficult to check.
I have read stories about fixing video cards with bad solder connections using a propane torch. Surprisingly, it sometimes does work.
Offline Time
« Reply #3 on: August 12, 2010, 11:54:11 pm »
I have used a heat gun to solder BGA and also a blow torch.
I like adding the hot plate idea.
-Time
Offline DJPhil
« Reply #4 on: August 13, 2010, 12:46:59 am »
blow torch
That's got to feel awesome. I'd feel ten feet tall for a day if I got that to work properly.
The closest I've ever been to that awesome was seating a tire on a rim with lighter fluid, then I found out it was a well known practice.
Offline abbtech
    • Alan's Electronic Projects
« Reply #5 on: August 14, 2010, 10:23:27 pm »
No idea how to do this. I would think a hot plate would be your best bet though.
Either way I would love to see the results. Take some pics along the way so we can see how it works!
Personal projects http://alan-parekh.com
Other cool project ideas http://hackedgadgets.com
