Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Projects, Designs, and Technical Stuff
Hairpin dip switch
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Hairpin dip switch (Read 848 times)
IconicPCB
Super Contributor
Country:
Hairpin dip switch
on:
September 12, 2019, 10:09:42 pm »
Used to be able to get a dip switch which consisted of two shaped pieces of wire per switch.
One part, the fixed part was in a shape of a hook so that the movable part could be forced downwards beneath the hook and would be retained closed contacting the hook.
The spring tension was sufficiently high to create a gas tight contact between the two parts of the switch according to the data sheet.
In order to engage or disengage the procedure was a bit more involved than simply toggling or sliding the slider.
It would fit in conventional 0.3" pitch array.
A hint of where it might be found would be appreciated.
Logged
IconicPCB
Super Contributor
Country:
Re: Hairpin dip switch
Reply #1 on:
September 12, 2019, 10:43:40 pm »
A photo of the said switch
Logged
SL4P
Super Contributor
Country:
There's more value if you figure it out yourself!
Reply #2 on:
September 13, 2019, 12:56:46 am »
I remember them, but haven't seen one in 20 years.
Any reason you're not interested in the more recent DIP switch offerings?
Last Edit: September 13, 2019, 01:38:24 am by SL4P
Logged
Don't ask a question if you aren't willing to listen to the answer.
Ian.M
Super Contributor
Reply #3 on:
September 13, 2019, 01:37:03 am »
I also remember them. Maybe the O.P. wants them because they are both washable in production and cleanable in service? OTOH, if as I suspect, the contacts are plated spring steel, rust may be an issue in humid environments.
Logged
SL4P
Super Contributor
Country:
Reply #4 on:
September 13, 2019, 01:39:14 am »
I also recall seeing them occasionally 'soldered' - once the initial configuration / resets had been completed.
Logged
IconicPCB
Super Contributor
Country:
Reply #5 on:
September 13, 2019, 01:46:15 am »
I seem to think they were a Siemens product.
It takes a certain effort to engage and disengage a contact forcing the brain to engage along the way.
The corrosion is a possibility but the image is of one such item assembled way back in early eighties ( say 83 ) no corrosion so far.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Hairpin dip switch
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
