Hello,
I am recycling an old handheld door buzzer in a project of mine and am familiarizing myself with its internals. It is from Linear Corp, model DXT-23, with part number SNT00377. It operates at 315MHz at 3.3 volts from two 2032 batteries. I have come across this RFM module where I cannot find a data sheet for it and websites that appear to be selling it do not have pictures of it to confirm it is the same part I am looking at. I have emailed support of who I think is the manufacturer (
https://www.rfmi.co/) is and they do not have the part number in the system. Any help is appreciated
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Bonus: If possible can anyone verify the value of this inductor? I have a rinky dink plastic caliper to measure the length and diameter. It's measurement were:
N: 10
Diameter: 2mm
Wire thickness: <1mm
length: 4.5
using a calculator I got .0072 micro H and noticed standard is .1 uH, if I tweak diameter to 2.4mm I get around that value. Let me know if you think .1uH is a good bet.
Here is Imgur Album with related photos (Board Overview, RFM up close, Inductor up close, board info, rinky dink caliper)
https://imgur.com/a/WYPXCOqThank you
