I have taken some pictures of the Kapsch 322631-011 / 12069-002 / PWJ1548G.
The epoxy was a little pig-headed but I finally was able to remove most of it.
The edge length of the die is 1,8mm. There is quite a big frame supplying the circuit.
The part was designed by AMI in 2000.
The small circuit on the left could be a clock generator...
I don´t think that is a damaged spot. But what should this structure tell us?
Too small...
That are mask revisions...
Most of the area is occupied by standard logic. In the upper right corner there is something different...
The typical standard logic. You can see the horizontal and the vertical supply lines. Between the horizontal supply lines there are the interconnections around the standard cells. The standard cells are too small to be identified. There are at least two layers of interconnection probably more. You can see the bigger lines on top of the other.
We can´t be sure what the special structure in the upper right corner does. Perhaps some memory? Probably...
There is an additional small circuit right of the memory (?) circuit outside of the supply frame. Could be a high voltage generator for an EEPROM.
There is one testpad in the upper left corner.
It´s possible to distinguish the inputs and outputs. The input bondpads (left side) have smaller connections than the output bondpads (right side). Above the output bondpads you can see two horizontal slots that are probably connections to the supply. There are also some more vertical lines probably the output stages.
It´s possible to identify the supply contacts too. At the upper edge there is a bondpad directly connecting the metal frame and on the left side there is a bondpad that is connected to the outer frame that probably connects the substrate. Normally that´s the most negative potential, GND in this case.
Take a closer look... ...the output stages are different in size.
https://www.richis-lab.de/transponder02.htm
