Author Topic: Unusual 74HC595 circuit design  (Read 1766 times)
Offline karan279Topic starter
  • Country: in
« on: October 07, 2013, 06:29:02 pm »
Hi all ,
here is a circuit i traced from a machine spare part for Looming , so it has this 74hc595 with its 2 pins the storage clock and shift clock connected via a resistor and cap , and all i can think of is maybe its done to save a pin , but could anyone tell who may have worked on such a design and how i could probably test it .
 :-/O :-/O
There are those who accept things as they are, and those who Rise to change them.
Offline dannyf
Re: Unusual 74HC595 circuit design
« Reply #1 on: October 07, 2013, 06:50:11 pm »
You are right. It is one of the oldest tricks in the book: short pulses will trigger one pin and low pulses another.
In the extreme, you could trigger a shift register like HC595/164 with one single pin.
  • Country: in
« Reply #2 on: October 07, 2013, 07:14:59 pm »
so i guess short pulses should trigger both the clocks  :)
Offline dannyf
« Reply #3 on: October 07, 2013, 07:21:45 pm »
Short pulses will trigger the one it is directly connected to. Long pulses will trigger both.
It relies on the rc constant of the r/c network: quick pulses doesn't change the voltage on the capacitor.
