Author Topic: Design of simple/cheap "spectrum analyzer"-like device  (Read 2312 times)
Offline JJallingTopic starter
« on: April 18, 2018, 09:41:43 am »
Hello,
As the title says, what I think I need, is a spectrum analyzer-like device.
I was contacted by a friend, regarding a fun little project. The goal of the project, is to monitor the S/N ratio or signal strength on 10-20 radio transmitters, each with transmitting with their own frequenzy in the 400MHz-450MHz range.
My first thought was to use a USB-SDR dongle and a small computer, but I don't find that solution very elegant. Does anyone have an idea of an alternative solution to this?
I'm sorry about the very vague description, but it is more or less what I know right now.
EDIT: Clarification about the project scope.
The goal of this project, is to have multiple receivers in a room (like sports arena) and do triangulation to calculate the relative position of the transmitters.
The reason for using the existing transmitters, is that we don't want to add more hardware/weight to the the devices carrying the transmitters.
Hopes that this clarifies it a bit.
BR Jonas
« Last Edit: April 18, 2018, 10:52:08 am by JJalling »
Offline kripton2035
Re: Design of simple/cheap "spectrum analyzer"-like device
« Reply #1 on: April 18, 2018, 10:05:35 am »
http://j3.rf-explorer.com/
available at seeedstudio for $99 model 433MHz
will cost you more to design your own.
« Last Edit: April 18, 2018, 10:07:19 am by kripton2035 »
« Reply #2 on: April 18, 2018, 10:36:08 am »
yes, besides the frequency range is too narrow, it could be a solution.
BR Jonas
Offline BravoV
  • +++ ATH1
« Reply #3 on: April 18, 2018, 10:48:34 am »
TI MSP-SA430 ?
Frequency Ranges:
    300 – 348 MHz
    389 – 464 MHz
    779 – 928 MHz
Quite costly though at $249.  :-\
There was a crazy sales by TI few years ago for this at only $25 with s/h included, and this made quite a riot of buying frenzy -> $25 Spectrum analyzer ...
« Last Edit: April 18, 2018, 10:51:21 am by BravoV »
Offline kripton2035
« Reply #4 on: April 18, 2018, 11:51:59 am »
BR Jonas
then you can go to the $175 model which has an ISM band.
still cheap compared to any other solution IMHO
https://www.seeedstudio.com/RF-Explorer-ISM-Combo-p-1092.html
Online MasterT
« Reply #5 on: April 18, 2018, 12:05:08 pm »
There is product line from SiLabs, Si4432 & Si4463. You may get a module on aliexpress.
Seems main objective is to build  a  radio direction finder. Quite easy for CW and AM, but you didn't tell what kind of modulation, if it's digital may be tricky or not possible in reasonable price range.
Offline SiliconWizard
« Reply #6 on: April 18, 2018, 01:10:17 pm »
If your project is strictly for indoor positioning, you may also take a look at this technology: https://decawave.com/products/overview
