Author Topic: Hacked Chinese reverb  (Read 1966 times)
Offline TeledogTopic starter
« on: April 01, 2024, 12:55:26 am »
So, bought a Grand "Fender reverb re-issue" reverb unit from Ali (supposedly free shipping)
Seller asked for more $$ for shipping, and I did so.
Arrived "not working". (got a $225 refund off a ~$600 investment)
The 6V6 plate/cathode had no connections, after adding/wiring the connections, ..it was intermittent (there was a fine strand of wire between some tube pins, may have been me, or?)
Anyway, decided to hack the "already beater" unit, added another tank (a MOD long, 3 spring-long decay) Original was a medium, 2 spring-medium decay.
Added a 3PDT switch, (for switching between tanks),  took out the dangling participle power cord & foot switch wires, added a PEM & jack, a "real" 1W tone pot, chassis nuts, etc..
Still a "beater" but it sounds great!
Offline MathWizard
Re: Hacked Chinese reverb
« Reply #1 on: April 01, 2024, 04:37:19 am »
Right so they use, or used to use, springs in amps for reverb. Someday I'll have to look up a circuit for that, and other effects. I play guitar once and a while, years ago I had a nice Marshall amp with springs for reverb. I can't guess how they use them in the circuits, to make reverb.
Offline pcprogrammer
« Reply #2 on: April 01, 2024, 06:51:23 am »
Very simple. The spring is driven at one end with something like a speaker coil and monitored at the other end with a pickup. The sound travels through the spring with a delay.
Offline CaptDon
  • Country: is
« Reply #3 on: April 01, 2024, 11:56:29 pm »
So sad, money spent off-shore for another non-working piece of shit.
Offline Andy Watson
« Reply #4 on: April 02, 2024, 12:44:14 am »
Basically it's a mechanical delay with plenty of resonances as a bonus! If you want something freaky (well .. I was freaked-out by it :) ) check-out Uncle Doug on youtube dabbling with an "oil can" reverb.
« Reply #5 on: April 02, 2024, 02:36:32 am »
And then there's the plate reverb;
https://youtu.be/u6eZ_JbmBDw
Wouldn't mind making one.. if I hade more real estate..
Here's how to (ab)use a stand-alone spring reverb.. notice the foot smashing/tilting of the unit for the crash sound
https://youtu.be/9M4dZw37i7s
And yes, the Jazzmaster & Gretsch sound great with it :-)
