I work at a University. A professor requested that I look into acquiring and modifying a 3D printer for her. Goal is to print various UV cured biomaterials.
As the 3D printer market is crowded and confusing, I figured I'd ask here first. Please only suggest machines that you have seen, used, borrowed, or otherwise have actual experience with.
Requirements:
Budget 1K to 2K for core hardware, and higher is better, we need not be cheap
Easily modified hardware/software. Preferably open source software
High quality printer with easy attachment of a print head, so when I build her the new print head, we do not have issues with mass/attachment /interface etc
High quality, good motor drives, microstepping, encoder feedback on Z if possible, encoders on XY would be delicious.
Space to attach moving UV curing lamp/fiber optic, or high power leds and heat sink
Prefer double or color changing print head
Understandable Windows Software environment, Linux only OK if the machine is a VERY special unicorn otherwise.
Lack of useless gimmicks
Good quality in bearings, leadscrews, high stiffness etc.
100 uM accuracy would be fine
Mainstream manufacturer that will be around a while, no fly by night garbage.
Material will be delivered by a external precision pump assembly to a syringe type nozzle, nozzle to be kept at 37' C for bio reasons
Ability to adjust system timing of everything, for obvious reasons
As much metal in the machine as possible, to aid in modification, ie no 3D printed parts in print head area if possible.
User / Target audience are Chemical Engineering Graduate Students, not an EE community
Suggestions? Material is a monomer with a gel like consistency that will not kill live cells. Monomer cure time is fairly long, so need to be able to print slowly. Because we may print live cells, the monomer needs very little UV to initiate a cure, by design. Objects to be printed are small, 4x4x 2 cm max. I have all the usual university tools, ie machine shop, electronics shop, CNC, everything but a dedicated programmer. I have 15 years in the research support business, so "complicated" is the norm in my life. We do have some experience in 3D printing in the department, but nobody is going to let me Mod/Hack the Stratasys down the hall.
Steve
