It’s been a while since I last posted as I haven’t had much time to work on this project, but I managed to build up the op-amp based ground rail and do a few simple tests. One thing that I noticed is that my output swing is much more limited. Previously I could get over 3.5Vpk-pk output at 1kHz.
I can get about 1.75Vpk-pk output (1kHz sine) at most before distortion, but the shape of the distortion is strange. It happens on the lower half of the waveform by sneaking in and cutting it off.
The upper half starts distorting when the output reaches about 2.5V.
I’m not too sure what would be causing this other than the op-amp may not be able to put out enough current to maintain ground? The point at which distortion starts is frequency dependant. At 200Hz I can’t get more than 1Vpk-pk output before distortion begins,
but at 10kHz I can get more than 3.5Vpk-pk.
