I would like to hear some opinions on my Kweld build before i actually build it. Any feedback or recommendations would be appreciated.
I am looking to make a "package" build, may be inside a small pelican case or similar enclosure. The build will consist of Kweld, 1 or more turnigy 130C batteries, or possibly a custom 4S Li-ion cell bank and a Tenergy Li charger.
I would like to push 1300Amps.
My questions/options are:
1. Do i need a mechanical disconnect between charger and battery power leads? Not sure how charger would react to 1300 amp pulse coming out of the batteries into kweld... If disconnect is needed to protect the charger, do i need it on both power and ground lines? How about on balance lines?
1.5 can i charge the li-ion battery with KWeld connected or do i need to disconnect it from charger/battery circuit with additional set of switches?
1.75 If i do not need to disconnect charger from battery when using kweld, can i actually use kweld while charging? Again, not sure about the whole inductive energy from pulse interaction with charger especially while it is charging the battery.
2. Is switching to 6AWG or even 4AWG a good idea or not worth it? Looking to have flexibility of longer leads but heavier gauge wire is going to require longer bend radius, reducing the flexibility added by additional length.
3. I am looking to add options such as ground clamp, to basically be able to do single point spot welding on larger "somewhat structural" materials, like nickel covers for wire routes etc, not "real structural" welds. What would you recommend for good quality disconnects to be able to swap between electrode sets? I am NOT trying to replicate the functionality of a MIG or TIG Tack/spot welder, just trying to enable myself to use kweld in as wide of a range of applications as possible. At work (aircraft company) we use very basic, but expansive, AC tack welders for this type of work. The energy output of those is measured in percent... so no where near the accuracy and flexibility that Kweld can provide.
EDIT:
4. Does it make sense to play with alternate electrode material like tungsten or graphite? I realize it has higher resistance than copper, but it also has higher melting temperature... While low resistance contact between electrode and nickel strip should result in minimal heating and damage to the copper electrode, it is still right ontop of the weld bead and basic thermal conduction will still heat it up. If we ignore the lower cost of copper, are there better options for the electrode set?
5. the power supply leads in KWELD kit have the ground wire shorter than power wire. What is the requirement driving this? My current configuration has the li-ion battery wire connected to the KWELD leads, so ratio of power wire lengths is now different than original ratio of supply wire lengths. In my final configuration i will probably have to build my own supply cables. Is there a specific ratio of supply cable lengths i should aim for? Or does this all come down to resistance hence if i use 6AWG for ground leg and 8AWG for power leg i do not need to worry about supply cable length ratio?
