My only concern regarding using Aluminium for the buss bars is the high reactivity of aluminium with the atmosphere. Aluminium oxide is a very poor conductor. Brass will also oxidise. Copper buss bars may be the best option, but also the most expensive.
I was considering what protection the bars may need to prevent such oxidisation becoming an issue over time. The old trick was to cover the area around the contact surface with an air excluder such as vaseline petrolium jelly. This may need to be considered but I do not think it is good to use it on the actual contact surface itself.
I've got the same feedback on other places, and I have started investigating it. I found a shop that sells galvanic articles, and it would be possible to add chemical zinc, and then galvanize with gold. That would be a good match for the gold PCB traces.
On the other hand, I have built an audio amplifier decades ago, and I still have the bulk capacitors with screw terminals that are connected with aluminum bars. The capacitor's screw terminals were made from tinned brass.
That makes me think: would it prevent contact corrosion if I would order tinned PCB's instead of gold plated next time?
What was the problem, the milling is it to tough or does the bit bite into the metal? It might be good as Fraser indicates to switch to Copper, but I will look into this myself.
Can you provide me (us) with the exact mechanical layout (thickness, length, wideness, and position of the holes and diameter) of the bars, than I can look at my local metaldump if I can find a suitable copper donorpiece and already start cutting it up and working on that
Do you think it would matter if the barr is made out of two or three parallel parts or perhaps made thicker, since it is the overall resistance that counts right?
I indeed had problems with drills biting into the metal, but meanwhile I have specialized soft metal drills that perform much better. The work steps on the brass bars are the following:
- cut to length
- measure and centerpunch all drill positions (I will use a template instead for "mass" production)
- drill 4.5mm holes
- drill 6.5mm holes
- deburr with countersink drill
- sand all faces
That sums up, wich was why I decided to set the price for that work relatively high. Also to prevent myself from drowning in machining work.
Here are the dimensions of the original brass bars. The new aluminm bar is identical but is only 4mm thick (the maximum that my provider can laser with this contour).
![](https://www.eevblog.com/forum/projects/guesses-on-what-i-am-attempting-here/?action=dlattach;attach=336868)
