Author Topic: kWeld - "Next level" DIY battery spot welder  (Read 347232 times)
Offline tatus1969Topic starter
  • Resistance is futile - We Are The Watt.
    • keenlab
« on: June 13, 2017, 09:16:01 pm »
I have received parts for a small project that I haven't found realized in the way that I am attempting it. For today, just a picture. That AWG8 cable assembly took me two hours to finish :o
Any creative idea of what this is going to become in the end? ;)
« Last Edit: July 17, 2017, 03:57:12 pm by tatus1969 »
We Are The Watt - Resistance Is Futile!
The following users thanked this post: aterren, oasis2020
Offline Paul Price
Re: Guesses on what I am attempting here?
« Reply #1 on: June 13, 2017, 09:38:57 pm »
A waste of time.
The following users thanked this post: Zucca, Yansi, james_s
Offline Paul Price
« Reply #2 on: June 13, 2017, 09:41:52 pm »
2nd Guess: Remote voltage sensing also incorporating a fused power connection.
Offline CM800
« Reply #3 on: June 13, 2017, 09:49:37 pm »
Depends... what is that black brick?
if it's a FET... coilgun! :D
Offline Electro Detective
« Reply #4 on: June 13, 2017, 10:54:36 pm »
Some sort of payback device for a Neighbors From Hell electrical switchboard ?  >:D
 :popcorn:
Online MK14
« Reply #5 on: June 13, 2017, 11:04:25 pm »
You using a PMSM servo motor, at 2,000 Watts (we are!), to stack an extra third road traffic cone, on top of two nicely stacked on top of each other ?
The following users thanked this post: tatus1969
Offline buck converter
« Reply #6 on: June 13, 2017, 11:23:34 pm »
welder?
Just me and my scope.
Offline Koen
« Reply #7 on: June 13, 2017, 11:29:19 pm »
A very-rugged armband for your smartphone ?
Online MK14
« Reply #8 on: June 13, 2017, 11:35:04 pm »
48V, 40 Amp, Connector to a/the Motor (controller elsewhere), 2,000 Watt. With directional control, the black, four terminal block being some kind of powerful diode block/pack.
Offline mjkuwp
  • mechanical engineering defector
    • The Mz Lab
« Reply #9 on: June 13, 2017, 11:52:52 pm »
To me it looks like a hookup for  a power meter, but that is not a creative idea on my part : (
Offline StillTrying
  • Country: Broken Britain
« Reply #10 on: June 13, 2017, 11:53:19 pm »
Remote switch off.
Two pin power connector tester, because that looks like it would be the first part to blow!
Offline BrianHG
« Reply #11 on: June 14, 2017, 12:47:09 am »
A solar battery charger/inverter switch.
Offline P90
« Reply #12 on: June 14, 2017, 12:58:12 am »
2 hours?
You're fired!   :-DD
The following users thanked this post: SKHILLBILLYSlures
« Reply #13 on: June 14, 2017, 02:26:56 am »
2 hours?
You're fired!   :-DD
Time flies when you want to make sure it's done right  :-+
The picket lines will be in place tomorrow morning :rant: :box: :blah: :bullshit: :clap: unless he gets his job back
Any cheap scab labor trying to get past may experience an accident    >:D
Offline P90
« Reply #14 on: June 14, 2017, 02:39:10 am »
2 hours?
You're fired!   :-DD
must be union... :palm:
Offline macona
« Reply #15 on: June 14, 2017, 05:20:22 am »
I think I would be using anderson power poles instead of RC car connectors.
And 2 hours??? How?
    • keenlab
« Reply #16 on: June 14, 2017, 05:22:45 am »
 :popcorn:
That must be really a switchboard right from hell if it uses Deans T connectors  >:D
    • keenlab
« Reply #17 on: June 14, 2017, 05:24:09 am »
:-DD you're well informed, but not even close ;)
edit: except for one part: resistance is supposed to be futile in this case as well 8)
« Last Edit: June 14, 2017, 07:22:07 am by tatus1969 »
    • keenlab
« Reply #18 on: June 14, 2017, 05:26:13 am »
And 2 hours??? How?
The connector scares worries me a bit too, but the counterpart is already there...
« Last Edit: June 17, 2017, 11:00:52 am by tatus1969 »
    • keenlab
« Reply #19 on: June 14, 2017, 05:33:24 am »
2 hours?
You're fired!   :-DD
I should have quit that job because of poor working conditions! The crimp tool didn't take the AWG8 without adding a hammer, the soldering iron didn't like that cross section either, and where's my electronics side cutter???
*cough* almost forgot that my boss is again me in this case ::) At least I am happy that I have found a proper space for my hobby now :)
The following users thanked this post: Electro Detective
Offline tautech
« Reply #20 on: June 14, 2017, 05:54:41 am »
Run isolator for charging your electric scooter conversion.
    • keenlab
« Reply #21 on: June 14, 2017, 06:51:17 am »
spoiler alert: the correct anwer was already given :clap:
Offline CM800
« Reply #22 on: June 14, 2017, 09:19:57 am »
 At least share what silicon it is...
I stand by coilgun.
http://4hv.org/e107_plugins/forum/forum_viewtopic.php?147269
    • keenlab
Offline technix
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
