I chose silicone high flex because a) it eases electrode handling and b) it is 200°C rated and won't immediately burst into flames when something unwanted happens.
Ah yes and you solder that wire to the electrodes that will also need the insulation of the wire to withstand the higher temperature.
Well I found bigger silicone wire (16mm
2 upto 120mm
2) from HELU or LAPP and othere manufacturers at
www.tme.eu , a bit pricy but available if needed to lower the resistance even further
![Cool 8)](https://www.eevblog.com/forum/Smileys/default/cool.gif)
I dream of one of these ![Azn ^-^](https://www.eevblog.com/forum/Smileys/default/azn.gif)
me too, I so hope that the deal goes through, a dream would come true.
He even has one with 120A
![Shocked :o](https://www.eevblog.com/forum/Smileys/default/shocked.gif)
but that one he wants to keep to jumpstart his wifes car, he says he puts it at 16V and can start the car without battery just on that one power supply.
A bit rediculous because the listprice of these supplies are >5k€ but he has gotten them cheap so yeah if he has a practical use for it who am I to judge but I know some people that read this will burst in tears.
I have some Maxwell BCAP0310 P270 T10 here,I'll keep you updated!
Great! I am looking forward of hearing the experience.
Supercapacitors don't like being overcharged, similar to Lipos. In a similar way, they need balancers when connected in series. For low current applications, that can be a simple resistor, but in our cases we need an active circuit. Typically that is a (e.g. 2.6V) comparator that switches a transistor which connects a resistor in parallel with the cell.
If I get this correctly if you have 4 supercaps in series and charge it with a controlled Voltage of 10V, still one of the caps might get more than 2.6V due to imbalances in the capacitors?
Than a balancer circuit is also on the shopping list
