Author Topic: How to better connect decoupling caps with BGA on top side?  (Read 794 times)
Offline gandiTopic starter
  • Country: at
« on: March 23, 2021, 01:33:31 pm »
I am currently designing a board for a display that includes SDRAM, NOR flash, ethernet, USB,...
The board should "stick" on the back of the LCD panel, therefore I have to put all components
on the top layer.
I have positioned the caps on the outside of the BGA package and now I need some help
to determine which wiring strategy is better or which one is a no go.
Stackup: #1 High Speed, #2 GND Plane, #3 & #4 Low Speed, #5 Supply Plane, #6 High Speed
1. Using solid supply plane
1200720-0
2. Supply plane with keepout area and track for every supply pin
1200724-1
Is the first one bad for decoupling behaviour?
Does the second one need a GND plane in between to keep the impendance
of the tracks on layer #6?
BR Martin
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
Re: How to better connect decoupling caps with BGA on top side?
« Reply #1 on: March 23, 2021, 02:56:49 pm »
I would definitely go for the first one. That's about as good as you'll get with components on one side (BGA pinouts are generally chosen on the assumption that you'll put the decoupling capacitors on the back).
The following users thanked this post: gandi
  • Country: at
« Reply #2 on: March 24, 2021, 07:10:43 am »
tank you for the quick response.  I will use the first pattern.
