Author Topic: I'm looking for an I2S Audio DAC  (Read 2292 times)
Offline SpiderElectronicsTopic starter
« on: December 11, 2012, 03:12:29 pm »
Hi everyone.
A design I am refreshing currently uses an AK4366 Audio Dac with I2S interface.
It's a 24 BIT Audio DAC, up to 48khz sampling rate, with 3.3v VCC
I can't find a supplier in the UK for this chip anymore. Neither Farnell, DigiKey nor RS stock it.
Can anyone suggest a reasonable quality Audio DAC with I2S Interface that I can use in place of this?
Doesn't need to be an exact replacement.
Offline Christe4nM
Re: I'm looking for an I2S Audio DAC
« Reply #1 on: December 12, 2012, 04:50:10 pm »
I remembered my stm32 discovery board has a Cirrus Logic one, so I looked it up for you: it's the cs43l22. http://www.cirrus.com/en/products/cs43l22.html If this isn't what you are looking for try their website for similar devices.
Offline jeroen74
« Reply #2 on: December 12, 2012, 09:06:17 pm »
wm8524
Carried by Farnell. Cheap as chips too.
