Author Topic: Electron gun power supply issues: Stumped by a current meter  (Read 23910 times)
Offline gcewing
Re: Electron gun power supply issues: Stumped by a current meter
« Reply #25 on: December 31, 2021, 12:13:06 pm »
Are you sure your rectifier is actually doing full-wave and not half-wave for some reason?
Offline ChristofferBTopic starter
  • Chemistry phd student!
    • My channel:
« Reply #26 on: December 31, 2021, 02:35:12 pm »
The rectifier bridge is doing something strange, that's for sure. Bridge output to the meter is a 100 Hz sine wave shifted up to be all positive.
This then makes sense that the meter only shows about half, but I still don't get the bridge behavior..
Increasing the capacitance across the meter/bridge to 10 uF gives some DC component, but not much..
The RMS voltage across the meter is close to 100 mV, which would translate into 0.5 mA through the meter, which would give the expected reading, so the current transformer and meter are working as expected.
--Christoffer //IG:Chromatogiraffery
Check out my scientific instruments diy (GC, HPLC, NMR, etc) Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
    • My channel:
« Reply #27 on: December 31, 2021, 03:36:41 pm »
Looping the high current lead once more through the transformer gives much more predictable results!
I now see the exact output one would expect from a rectifier, so I guess at 6V primary, the induced voltage in the secondary had trouble turning on the diode junctions.
The scale is now reading slightly too high, however. 0.7 FS (supposed to be 0.7A) with 0.5A input. I guess I could make all the resistors trimpots and just set it.
Offline NiHaoMike
    • Facebook Page
« Reply #28 on: December 31, 2021, 03:45:56 pm »
Might want to try a voltage doubler with Schottky diodes.
Offline Kleinstein
« Reply #29 on: December 31, 2021, 04:16:26 pm »
The current transformers have a limited voltage. It depends on the number of turns, and with a relatively low number of turns the diode drop may be already on the high side. So a rectifier with shottky diodes may be more suitable.
    • My channel:
« Reply #30 on: December 31, 2021, 07:03:00 pm »
That's what I figured, eventually.
I just made two turns through the current transformer and replaced the resistors with trimmers to set the readout to a known value. A bit of a kludge but it's working as intented.
Thanks for all your advice and happy new year!
