Author Topic: new use for a howard group pal colour bar generator ep872gb  (Read 506 times)
Offline p.larnerTopic starter
« on: October 07, 2023, 03:02:33 am »
hi,i have been given a howard group pal colour bar generator ep872gb,it was from a friend closing down his tv repair shop,the unit is in nice condition,it seems a shame to break it,is there anything usefull it can be used for ,or anything it could be made into to be of use nowadays?.
Re: new use for a howard group pal colour bar generator ep872gb
« Reply #1 on: October 13, 2023, 09:45:07 am »
anyone?.
Offline Terry Bites
« Reply #2 on: October 13, 2023, 03:40:57 pm »
If you had a schematic.....
Take your signal gen and mix stuff into the composite waveform- keep the dc level of the added signal above sync.
Sum the output with your randoms with a couple of 150 ohm resistors.
