Thanks.
My unit only has the GPSDO board and a small MeanWell power supply. (Switching type) My plan is to either replace it with linear supply or work on filtering output. I haven't gotten that far yet. My case is 1U rack mount, so what I can do is really limited.
As far as front panel goes, I intend to have a few LEDs only. Maybe POWER, LOCK, and PPS. I should be able to do this with a smallest Aduino. Anything further, I'll do it remotely via RS232C connection. Rear panel has Antenna, 10MHz out, 1 pps out, and power. That's it. Very simple.
While your oven is warming up, do you see frequent UNLOCKs? (shown as red-line on top of LH graph) and status other than zero? I kept having that problem for long time until I closed the lid and let it warm up quickly.
I bought a bunch of Extron 3 output unit. I intend to take it out of case and use it as modules. These are really nice and cheap. Performance is pretty good, too. For general distribution in my lab, I already have two 12 channel distribution box.
