Author Topic: Air fluctuations indoors - detecting/measuring?  (Read 4016 times)
Offline floobydust
Re: Air fluctuations indoors - detecting/measuring?
« Reply #25 on: October 12, 2018, 01:50:11 am »
You can easily detect a slight breeze with a thermistor.
Put enough current though it that it self-heats, and any convection cooling changes will lower its resistance.
Seen this used before on candle simulators and a motion-sensor for a halloween gag.
Using a 100 ohm PTC thermistor and 100 ohm resistor to 5VDC, its about 4% R change per degree, lots for an A/D to look at.
