wow, thats really cheap. Well, you got a fabulous deal. You can use them for timing as well as make a super accurate GPS out of them.
By super accurate I mean accurate to a few cm, with a decent antenna and a clear sky view. You can set up your own base station and do RTK using RTKlib. They are extremely sensitive.
What firmware revision are they, can you launch GPS Viewer and extract the firmware and hardware patch levels?
