Author Topic: Does this circuit look correct to connect DA-15 (Gameport/MIDI) to RPi (MT32Pi)?  (Read 444 times)
Offline sofakngTopic starter
I'm trying to connect an older PC with a DA-15 (Gameport/MIDI) to a Raspberry Pi using MT32Pi.
The Gameport/MIDI is +5v and the RPi is +3.3v so I'm using an optocoupler and voltage divider.  I can't use the +3.3V on the RPi because it's not exposed on the device I'm using.
Does this look correct or could it even be simplified?
1364780-0
Ignore the MIDI CONN FEMALE in the center.  It's only there to visualizer the MIDI wires.
Thanks so much for any help!
