John Guy has made available gerbers on Oshpark
https://oshpark.com/shared_projects/2RLfokAb With some more modern components
All component values and reference designators changed from article though. All load resistors are off PCB too. Use 1% through hole resistors mounted to output banana jacks. U1 is REF3012, U2 is OPA313, and U3, optional, is TPS3702AX18DDCT for checking battery voltage. This version will work off 2 x AAA batteries.
